DEVELOPERS FORUM - Close the Workflow Process
Hrishikesh - Thursday, March 3, 2011 7:22 AM:
hello all,
           When i Close the Workflow Process from an Activity Method, the Error Occurs as " The Workflow Process Should be in Active State " But the Workflow Process is in Active State.
I am checking the two Activity are in Active State then only the Workflow Process should be Closed.
If Activity1 State is in Active and Other is Activity2 State is Pending but i am making Activity2 State  to Active from Coding.
i tried as follow,
  // Item of Workflow Process
wfProc.closeWorkflow();
or
wfProc.setAttribute("action","edit");
wfProc.setProperty("state","Closed");
wfProc.setProperty("current_state",clsdStatId);
wfProc.setProperty("closed_date",curDate);
Item wrkFlowProcess = wfProc.apply();
or
wfProc.setAttribute("action","PromoteItem");
For all above option i tried but the Error was same " The Workflow Process Should be in Active State "
so please help as early as possible.
Thank you all.
Hrishikesh
